 ВЫП (DSG, S-tronic) Следующая тема
СообщениеДобавлено: Вт Фев 02, 2010 3:53 am Ответить с цитатойВернуться к началу
вот нашел в сша и гон-конге
http://www.td.gov.hk/filemanager/en/content_1179/10000294.html
Description of Defect, how it came to light, and possible consequences if ignored.
On vehicles with 6 speed direct shift gearbox (DSG) of a certain production period a wrong interpretation of the clutch temperature by the gearbox control unit is possible, which indicates an overloading of the clutch. As a the result the clutch protection is activated (flashing gear display, juddering of vehicle, reduction of engine torque, opening of clutch). The vehicle can be used till it is checked/repaired. A faulty sensor normally leads to juddering and flashing of the gear display. There is no danger for the consumers.
Remedial Action
The affected vehicle receive an updated gearbox software.
Build Dates September 2008 to August 2009
Launch Date 27 December 2009
Tentative Date of Recall Completion 31 March 2010
http://media.vw.com/index.php?s=43&item=491
Volkswagen Group of America Announces Customer Service Program
Aug 28, 2009
This new comprehensive service program affects a limited number of model years 2007-2009 Volkswagens and Audis. Covered models are the Volkswagen R32, Jetta, Jetta SportWagen, GTI, Eos, as well as Audi A3 and TT.
Some customers have reported transmission performance issues under certain driving conditions. This was due to a faulty component inside the Mechatronic unit within a limited production range.
VWGoA will repair or replace the components in the transmissions of approximately 43,000 Volkswagens and 10,300 Audis at no charge to the vehicles' owners.
The company will extend its New Vehicle Limited Warranty to cover the DSG(® )transmissions affected by the customer service program and the voluntary safety recall. This extended warranty is for 10-years/100,000-miles, transferrable to subsequent owners.
Customers who have questions or concerns should call the Audi Customer Relations Campaign Help Line at 1-800-253-AUDI (2834).
итого: гарантия 10 лет или 100000 миль, да еще с правом передачи следующему владельцу.
есть и косяки: ВЫП 2006 го года отзыв не покрывает, ФВ отмалчивается.
А где живой отклик представительства Ауди в России или Фольксваген Груп Рус?
СообщениеДобавлено: Вт Фев 02, 2010 4:19 am Ответить с цитатойВернуться к началу
Как самому заменить жидкости в ДСГ http://forums.vwvortex.com/zerothread?id=3182504
В виде ПДФки http://forums.vwvortex.com/zerothread?id=2877262&uid=116753&dir=1&postid=32870655#32870655
База знаний по DSG (S-tronic) http://forums.vwvortex.com/zerothread?id=3289959
30edition
СообщениеДобавлено: Ср Фев 03, 2010 7:03 pm Ответить с цитатойВернуться к началу
на каком пробеге менять масло в дсг???
я гоняю на ТТ МК2 2.0 турбо
СообщениеДобавлено: Ср Фев 03, 2010 8:07 pm Ответить с цитатойВернуться к началу
как в сервисной книжке - 60ккм кажется
стоит ли вестись на песни дилеров каждые 30ккм - дело личное
30edition
СообщениеДобавлено: Чт Фев 04, 2010 1:04 am Ответить с цитатойВернуться к началу
а скоко в сервисе стоит заменить масло?? у меня пробег 34 000тыс стоит уже поменять??
Алексей вологда
СообщениеДобавлено: Чт Фев 04, 2010 9:43 am Ответить с цитатойВернуться к началу
Я менял...
Now: RS6 Plus
Was: Audi TT MK2 3,2 DSG
СообщениеДобавлено: Чт Фев 04, 2010 8:47 pm Ответить с цитатойВернуться к началу
40 может
anton69
СообщениеДобавлено: Чт Фев 04, 2010 9:23 pm Ответить с цитатойВернуться к началу
А DSG стоит на мкII или на мкI тоже ставили ?
30edition
СообщениеДобавлено: Чт Фев 04, 2010 9:25 pm Ответить с цитатойВернуться к началу
сколько стоит замена масла в дсг?
СообщениеДобавлено: Чт Фев 04, 2010 10:29 pm Ответить с цитатойВернуться к началу
на мк1 ставили с мотором 3.2 в последних версиях
глаза подними
Алексей вологда
СообщениеДобавлено: Пт Фев 05, 2010 9:45 am Ответить с цитатойВернуться к началу
Какие 40, вы чего?
Масло в районе 7 и работа 2-3...
Now: RS6 Plus
СообщениеДобавлено: Пт Фев 05, 2010 10:20 am Ответить с цитатойВернуться к началу
я отсюда по памяти
http://audi-club.ru/forum/showpost.php?p=3791572&postcount=3
и потом - тебе и тормоза вкрячили на халяву, а в мск 100круб запросят
Serge
СообщениеДобавлено: Пт Фев 05, 2010 11:03 am Ответить с цитатойВернуться к началу
Менял масло в DSG в ноябре.
Заплатил 12 тыс. вместе с работой
Алексей вологда
СообщениеДобавлено: Пт Фев 05, 2010 3:32 pm Ответить с цитатойВернуться к началу
Почему на халву? Железяки вышли под сотку(я уж не помню, но около того)...
Или в МСК за работу 100т.р. просят?
Now: RS6 Plus
Porto
СообщениеДобавлено: Пн Мар 22, 2010 4:02 pm Ответить с цитатойВернуться к началу
У меня было то 30 но масло в коробке не стали менять это нормально?
vikeis
fap-fap
СообщениеДобавлено: Пн Мар 22, 2010 4:13 pm Ответить с цитатойВернуться к началу
нормально) на 45 меняют масло в коробке
СообщениеДобавлено: Пн Мар 22, 2010 4:28 pm Ответить с цитатойВернуться к началу
ниче так износ - типтроник вообще чуть ли не пожизненно без замены можно
Porto
СообщениеДобавлено: Пн Мар 22, 2010 5:19 pm Ответить с цитатойВернуться к началу
А тебе меняли на 45??Сколько вышло по деньгам и где менля???
СообщениеДобавлено: Пн Мар 22, 2010 5:29 pm Ответить с цитатойВернуться к началу
нет
у меня пробег 15
Antoxa
СообщениеДобавлено: Пн Мар 22, 2010 5:32 pm Ответить с цитатойВернуться к началу
Немного не в тему, но раз уж речь зашла о типтронике: по сервисной книжке на скольких там масло надо менять?
